Please help identify this JLC
vincec
Postby vincec » Tue Nov 22, 2016 9:15 am
Greetings!
Please help identify this JLC. Apparently it is from the 50s-60s, could anyone confirm that?
Is there any way to tell if the dial was refinished?
Also, was it common practice for JLC to use "LeCoultre" signed casebacks?
Details:
Dimensions 33x26mm excluding crown
Lug width 20mm
On the caseback (from the outside), there are two lines of numbers: "981582" on the top, and "V877" on the bottom.
Any help would be greatly appreciated. Thanks in advance!
Vince
Re: Please help identify this JLC
Postby zafbasha » Tue Nov 22, 2016 11:28 am
"LeCoultre" signed back on vintage JLC is normal. I'm a bit surprised it doesn't indicate what the case is made of. Can you post a photo of the back from the outside?
vincec
Postby vincec » Tue Nov 22, 2016 11:56 am
Thank you very much for the response.
Does the caseback condition look too pristine for its age to be an original?
I've also added a photo of the crown as well as a better shot of the face.
Thank you once again for your time!
Users browsing this forum: No registered users and 44 guests
