Help Identifying Vintage LeCoultre 1930 Reverso
le.gentleman
Postby le.gentleman » Sat Jan 12, 2019 2:12 pm
Dear ladies and gentlemen, I was wondering if you could help me find out more about this watch, as I am a bit confused.
1. I acquired this vintage 1930s reverso LeCoultre Watch in Stainless Steel.
2. I am not quite sure about the date. The movement serial indicates it is from 1931 but I thought LeCoultre did not have their own movements until later. Also if you look at the dial it has the 6 o'clock seconds and so far I found that people say this did not happen until 1934.
Ws this watch put together later?
3. You can also see the case number
4. In an upclose shot it looks like the dial was repainted. I have never seen this type of dial for a 1930s reverso anywhere else, have you?
Any information is appreciated.
Re: Help Identifying Vintage LeCoultre 1930 Reverso
Postby zafbasha » Sun Jan 13, 2019 10:18 am
The pic uploads didn't work.
le.gentleman
Postby le.gentleman » Sun Jan 13, 2019 3:09 pm
Hi Zaf, I do not know why. I think it is the shortcode as the URLs work.
https://imgur.com/kIV6N1W
https://imgur.com/EiBGQr4
https://imgur.com/3LAAdba
https://imgur.com/lcsdXxj
Postby zafbasha » Tue Jan 15, 2019 10:40 am
The dial is definitely repainted. I'm not sure iof that hands are original. The crown has been replaced.
The movement probably dates to 1933 at the earliest. The serial look up is +/- 2 years so it's within the margin for error.
le.gentleman
Postby le.gentleman » Tue Jan 15, 2019 6:47 pm
Thanks Zaf, I appreciate it. If the serial number is plus minus 2 years that makes more sense because it seems like the 6'o clock seconds did not launch until 1934.
The repainting can be seen in the high res pic but when I wear it it is not noticeable.
I am having it services at the moment, and the case welded so it should be good to wear.
What did an original crown from the time look like?
Postby zafbasha » Wed Jan 16, 2019 1:22 pm
Original crown is plain, slightly larger than what you have but it has no step. Yours has a small step. The knurls are finer, i.e. more of them that what is on it right now.
Users browsing this forum: No registered users and 42 guests
